    Hi all,
    I like to work on small brass parts mainly for clocks so they can be quite small parts. The parts I work on usually have a thickness of 3.0mm but they can be 1.0mm if I want to machine some clock wheels. Generally I am machining right through the material. My question is can anyone give me some ideas on fixturing as currently I am really struggling. I use bits of wood, usually my project fails because of poor fixturing so I end up making with hand tools.
    Regards
    Steven
    Two approaches. One, prepare your gcode with CAM that can insert holding tabs in non critical areas so you can screw the blank down to a wood base. I use Cambam. Second, a layer of blue masking tape on both the stock and the spoil board, then superglue the stock down. Prise the work off when cut and boil in water to release the glue. I used to use this mainly but now tabs most often.
    Is blue masking tape double sided tape? Never tried this method.
    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Sounds like the kind of parts I'd do on a vacuum table, but the parts I do I'm happy to not fully machine through, and then finish with a sharp knife and deburring tool.
    Tabs and/or gluing the parts down are all workable options, but you'll likely need a mix of options depending on the part.
    Quote Originally Posted by swood1 View Post
    No, double sided tape usually has too much "give" / movement because it is thick and soft.
    Blue tape method:
    Layer of blue painters tape (masking tape) on flat machine surface
    Layer of tape on flat workpiece / sheet of brass
    Superglue one side and hold down firmly until glue dry
    Many videos on it available
    I thought the makers of clocks had switched from shellac to super glue. Either way you heat it up when you want it to let go
    I am cutting clock parts and I use a thin double sided tape used and sold for hold down small engraving parts, it works really well.
    http://www.pantograph.co.uk/pdfs/accesories.pdf there is low tack and high tack depending on what you need to hold down, far quicker and easy clean than using super glue and blue tape.
    When I design a sheet of clock wheels to cut out I put a strip of D/S under and also cut out the centre holes first and drop a screw in to hold each in place whist all the crossing cut outs are done then follow up cutting the disk out I only use tabs for parts with no screw holes.
  1. Work holding - Wax
    By matt-b2 in forum Metalwork Discussion
    Last Post: 20-06-2020, 07:51 AM
  2. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  3. Work Holding Tape/glue
    By andy_con in forum Woodwork Discussion
    Last Post: 22-07-2016, 06:39 PM
  4. RFQ: lathe work brass pins small
    Last Post: 20-01-2015, 03:41 PM
  5. RFQ: Looking at getting some small parts machined using Brass.
    By ryanlownie in forum Projects, Jobs & Requests
    Last Post: 26-10-2011, 11:44 PM
