Page 2 of 2 FirstFirst 12
    video
    https://youtu.be/stbWpra7O_4
    so you can hear the z stepper moving the z axis
    All thoughts welcome
    Any chance that it is a coupling or pulley slipping? Engraving - especially if you are V-engraving - tends to generate a lot of Z movement which might be aggravating something? I am assuming that nothing in the settings has changed.
    no, it only happens when the spindle is on
    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 16-07-2024 Has been a member for 9-10 years. Has a total post count of 85. Received thanks 3 times, giving thanks to others 11 times.
    I wondered if you're getting issues from having the boards sitting on that pink bubblewrap. It's antistatic, hence may have some level of conductivity - maybe even enhanced by humidity - so it could feasibly be affecting the connections on the underside of the PCBs. Since you seem to be getting noise related issues, I'd suggest replacing that with something a bit more inert. In an ideal world you'd screw the PCBs down with spacers off a backboard of some kind, so nothing touches the backs of the PCBs. But for starters you could always try a bit of hardboard or MDF in place of the bubblewrap? Easy to try even if it's not the cause of the problem!
    Quote Originally Posted by GND View Post
    now done this and its not made any difference
    heres an interesting development.
    so when the z is at its height it would be machining at i get this z movement issue. if i lower the z right down to near the table, in a position it wouldn't be machining at i dont get the z issue.
    so am now wondering if its some kind of cable issue. about a year ago i did have a cable break on the inside on the atc, the years of movements must have broken the cable.
    i appear to be finding more issues than solutions at the moment!!
    just opened the black box at the back of the machine and noticed the below.
    goo coming from the black hose connector block and then the electrical block below is wet. its gone all the way to the bottom connector.
  1. Gantry to bed height.
    By m.i.k.e in forum Gantry/Router Machines & Building
    Last Post: 05-07-2020, 05:46 PM
  2. Tool height sensor.
    By Ollie78 in forum General Discussion
    Last Post: 27-06-2019, 09:32 PM
  3. Z axis height setter
    By phill05 in forum General Discussion
    Last Post: 29-11-2016, 01:14 PM
  4. Z Height - Max?
    By Chaz in forum Gantry/Router Machines & Building
    Last Post: 04-02-2016, 11:18 AM
  5. Height Mapping?
    Last Post: 26-10-2012, 11:40 PM
