04-01-2023 #1
Hi all,
I’ve been having an issue with my Triac that I just can’t fathom!
At first I thought it was programming error on my part, but I’m quite sure I’m not to blame after all!!
I’m getting an intermittent issue that only seems to effect the y-axis.
Machine homes in XYZ with no issue.
After a G28/home/Toolchange *occasionally* when returning to position, I would get a deviation of approx. 5mm to the negative; i.e. tool at X0Y0, toolchange, return to X0Y0 by shown program position but physically returns to X0Y-5.0.
My datum stays constant so program position and machine position are shown correctly, but are physically out.
Re-homing out of program resets to correct position and X0Y0 is actually X0Y0.
I removed bellows and cleared swarf and chips from the casting and around the switch gear.
Cleaned it all, contact-cleaner applied to the micro switches and tested fine.
Positioning, toolchanging and repositioned fine, though didn’t get to ‘run in anger’.
Went to make a part tonight and had the same, but the Yaxis deviation was more like 10mm!!
Program is all centreline, with no comp. But I am running a 5mm slot drill.
I can’t see how it would be a factor, but for ‘full disclosure’.
(Though it did cross my mind…more than once!)
What and where do I start with getting to the bottom of this?!
Your help and advice is appreciated!!
The Dreaded X axis stepper error using UC400ETH and UCCNC !!!
By dachopper in forum CNCdrive (UC100, UC300ETH)Replies: 64Last Post: 29-01-2021, 03:27 PM -
FOR SALE: Denford Triac - Fanuc OM with BT30 8 Position ATC
By jamesgates1000 in forum Items For SaleReplies: 2Last Post: 20-02-2019, 12:57 PM -
Starturn 8 - X Axis locked at home
By Dangle_kt in forum Denford LathesReplies: 9Last Post: 16-03-2017, 02:53 PM -
"HOME" position on a CNC Mill, switch locations?
By manofgresley in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 26-08-2014, 07:06 PM -
Z axis error woes
By HankMcSpank in forum Machine DiscussionReplies: 46Last Post: 18-02-2012, 03:07 PM
