    Hi, has anyone any experience with this spindle motor pulley on my Bridgeport Interact 1 series 2. I am changing the motor but wanted to reuse the pulley. I can get a 3 leg puller onto it but even with heat and a ton of force it only moved 1/8 of an inch and is now locked solid. It has two grub screws on the top (pic) which I have unscrews but wondered are you supposed to remove this type with an hydraulic feed contected to these two grub screw holes?
    Any help appreciated.
    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Are 100% sure there are no grubscrews on the side?
    And if there is, that they've not been doubled up?
    I'll check if they are doubled up in the morning m_c, I wonder what the grub screws are there for? Def none on the side.Click image for larger version.
  2. misaligned keyway - stepper shaft vs pulley
    By dsc in forum Stepper & Servo Motors
    Last Post: 25-02-2014, 03:25 PM
  3. pulley fit on motor shaft - force it on?
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 09-08-2013, 06:11 AM
  4. 16 tooth pulley HTD5 15mm on a 14mm shaft
    Last Post: 07-06-2013, 11:51 AM
  5. Stepper shaft size and pulley bore size problem
