Thread: Spindle and VFD help
Hey D man
Everything you need is on the parameter list page 29 of the manual
not sure what control board you have. if you are just trying to communicate with your spindle then
F0.1 select what power is the output normally for a spindle commination is 0v-10 so set that to 5 but double check
F0.2 what the max frequency? 400 is what i see for most motors so double check
F0.4 select how you want to comminate with your board. right now its prob just the panel. so set this to 1
CNC Spindle choice and supply options - 2.2 kw water cooled spindle and VFD
By dogboy in forum Machine DiscussionReplies: 16Last Post: 06-05-2023, 11:44 PM -
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM
