    Hello
    I'm upgrading my 2.2kw spindle and VFD to Fuling 5.5kw vfd and 4.5kw er32 3 phase spindle.
    I am debating the cable size from VFD to spindle.
    The spindle motor plate states 3 phase 380v 9amp. Its 3 phase into the VFD and 3 phase out to spindle.
    So would 16awg (1.5mm2) 4 core shielded be suitable- what would you use?
    If so,can any one recommend a supplier for 8m?
    thanks
    Al
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    1.5 should be fine, as 9A is within the ratings I can find (vary from 10-19A) depending on application, and I very much doubt you'll be making full use of the 9A constantly.
    Personally, for something that's flexing a lot, and with the potential to cost money should it fail, I'd spend the extra money and get some ChainFlex cable from Igus - https://www.igus.co.uk/chainflex/motor-cables
    Standard ChainFlex CF885 Motor is £4.02/m or £3.27/m if you buy more than 10m, although that has no oil resistance.
    If you want Oil Resistance, then look at something like CF30
  1. AT1 Single Phase to Three Phase Penske Spindle Woes....
    By Cozza in forum Spindles & Drive Motors
    Last Post: 14-07-2021, 10:01 PM
  2. Replies: 0
    Last Post: 10-05-2021, 05:32 PM
  3. Fuling DZB200 Inverter
    By dougie8 in forum Chinese Machines
    Last Post: 19-06-2020, 12:36 AM
  4. 3 phase spindle
    By terry1956 in forum General Discussion
    Last Post: 21-05-2017, 06:46 PM
  5. er32 spindle thread worn out anything i can do?
    By Lloydm in forum General Discussion
    Last Post: 01-08-2016, 10:32 PM
