Thread: Planning my first CNC machine
05-01-2024 #11
Have you found a commercial machine that uses your structure / axis setup? If you can't, that should tell you something.
I've never seen one (and I've spent a lot of time looking at machine frames / designs).
There are large machines with a Y axis at the bottom, a lifting Z beam, and X axis travelling across the Z beam
Axis naming convention for a vertical machining centre:
Standing facing machine
Z goes up and down
X goes left and right
Y goes forward and back
05-01-2024 #12
My concern is mainly that the movement on the designated X axis may not be accurate.It is analogous to a wide drawer and they are prone to jamming or going out of square quite easily because the short runners aren't long enough to provide directional stability and I suspect that the same situation will pertain here.I strongly suspect that a moving table on the Y axis only will be better for stability and a Z axis with bracing,that traverses the gantry would be better.I would probably go for some external diagonal bracing on the X axis too.What family of steppers are under consideration?
05-01-2024 #13
By the time you have bought all the materials it might be as cheap to but an off the shelf XY table and convert it. To build a machine you probably need a mill anyway,
https://www.arceurotrade.co.uk/Catal...able-400x145mm
Or buy a complete mill and convert that. You will learn nearly as much and have a higher probability of success and of achieving the accuracy level you want.
Help planning a small(?) router for aluminium please
By suicidal_orange in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 31-10-2018, 07:54 AM -
NEW MEMBER: Hello There. Planning for UK MechMate Build
By Macwood in forum New Member IntroductionsReplies: 12Last Post: 20-09-2017, 11:34 PM -
BUILD LOG: Small workshop CNC router, steel base, planning on ATC
By spresv in forum DIY Router Build LogsReplies: 24Last Post: 07-02-2017, 04:28 PM -
BUILD LOG: Planning and getting things together
By bobhome in forum DIY Router Build LogsReplies: 11Last Post: 20-12-2013, 07:26 PM
