Thread: Introduction
Hello everyone,
I'm Phil, I've previously built two CNC DIY Machines before, the 1st was a small 1000mm x 750mm Aluminum profile machine, and the 2nd
a slightly bigger/sturdier 1500mm x 1200mm Aluminium Profile Machine.
I've never had any experience with CNC Machines before 2019 but once I found out it's possible to build these at home I had to give it a go. Loved every minute of the build process, but struggled with the wiring side of things, then found a YouTube video from Router CNC and pretty much copied his wiring, as he was the 1st person I found in the UK who also used an AXBB-E controller which was what I had, he also explains what the different components do, so I nearly understood what I was doing!
Anyway I've now bit the bullet again and decided to build another Machine 100mm x 100mm box section Frame 3000mm x 1650mm, just waiting for some warmer weather so I can crack on from where I left off before Christmas. I'll be using all electrics from my previous build apart from a new ATC Spindle and VFD - Hopefully, this time I might get a bit more automation set up as last time I just had the Spindle as a manual on/off and manual speed control - maybe I could get some help off here with the wiring for this...?
Thanks for reading,
no doubt I'll be posting a lot more in the coming months
Cheers,
Phil
15-01-2024 #2
Welcome aboard.
I would like to say kudos to your craftmanship. Laudable.
15-01-2024 #3
Cheers, Ahmad, another area I'm not very good at is Welding, it's a shame I didn't have your expertise when I started the frame
NEW MEMBER: New Boy introduction
By Crunch in forum New Member IntroductionsReplies: 14Last Post: 04-05-2019, 01:17 AM -
NEW MEMBER: My introduction
By Ashish in forum New Member IntroductionsReplies: 0Last Post: 29-11-2011, 05:57 AM -
CNC Introduction.
By John S in forum Manufacturer NewsReplies: 0Last Post: 12-08-2011, 09:28 PM -
NEW MEMBER: Introduction
By mrpeja in forum New Member IntroductionsReplies: 1Last Post: 23-12-2010, 04:59 PM -
By madd in forum New Member IntroductionsReplies: 1Last Post: 04-12-2010, 01:31 PM
