24-01-2024 #2
At a quick glance, there should be a couple of wires going to ACM and 0V, just on the right of the terminal block. You are quite correct - there is something missing!
You have Mach3 on a PC but how is the PC then connected to the rest of the machine? Likely to be either a simple break-out board connected to a PC parallel port, or a motion control board connected via USB or Ethernet. Knowing what that board is, would help a lot.
There is also an internal parameter setting on the VFD that decides whether the VFD speed is controlled by a control on the front panel or the external input. There might be some other parameters that need setting - there are some cheat-sheets around online that might help. Long time since I configured my own so can't remember what they all are!
Cnc wiring!
By Cobey3289 in forum General ElectronicsReplies: 20Last Post: 27-01-2018, 02:35 PM -
Help with wiring
By masinecc in forum Plasma Table MachinesReplies: 10Last Post: 23-01-2018, 10:30 AM -
Excellent info here regarding electrical noise, ideal for panels and machine wiring.
By EddyCurrent in forum General ElectronicsReplies: 0Last Post: 19-10-2013, 12:45 PM -
help me for wiring
By ali hedi in forum General ElectronicsReplies: 0Last Post: 28-11-2010, 01:20 PM
