Thread: Failed servo/ encoder help
If you have access to an oscilloscope and make some breakout leads between the encoder and the driver you might be able to check what is happening. By this I mean intercept the encoder wires while it is connected to the driver. I would guess there is at least power, ground and probably 2 pulse trains (slightly out of sync with each other depending on the direction of rotation). Maybe a google search will tell you the pin outs, plus if it is incremental or absolute encoder.
Or perhaps you could figure out the wiring by arranging a breakout connection from a known working encoder to a driver. But this would only confirm that it had stopped working. Then it’s a decision on whether to buy another motor with encoder, or hunt around for a compatible encoder if they are sold separately.
Without a scope, assuming you know which are the pulse train pins and ground you could connect a multimeter and check the RMS Voltage of a pulse train at different motor speeds. The values would not mean much but a reading would increase or decrease with speed.
Encoder Fault
By jamesgates1000 in forum Denford LathesReplies: 5Last Post: 07-01-2021, 06:03 PM -
Failed toroidal transformer
By Neale in forum General ElectronicsReplies: 15Last Post: 05-01-2016, 11:45 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
re servo encoder
By Scott in forum General ElectronicsReplies: 6Last Post: 24-06-2010, 08:30 AM
