    Hey folks - long time lurker on the forum and need some advice.
    I’ve some exotic linear motors and a pile of heavy duty extruded aluminium. What to do with them!?
    I was going to build a new machine but life gets in the way so time for a clear out. Seems too good to weigh in at the scrappy though.
    It was a very high end sampling machine in it’s day. Cost about £500,000 10 years ago.
    The linear motors are things of beauty - but they’re a bit beyond me. One is rail is 1500mm other is 1200mm.
    The controllers have some literature available but way over my head!
    I’ve been tripping over them for 2 years now so need to do something about it.
    So what to do - try and get it all working**, weigh it all in, or split for sale?
    Anyone have experience with linear motors?
    ** even if I could figure it out I’ve no idea of torque values or anything else about the motors. It will be super accurate when up and running though - and I bet it crazy fast and fun to play with :o)
    Quote Originally Posted by monstermunch762 View Post
    You need the datasheet to make it work
    https://www.nskamericas.com/en/produ...nocarrier.html
    I don't see it, I can't see the drive on the ones you pictured
    RS232 is a serial port to talk to a PC, probably so you can program the driver
    The IO looks like a parallel port
    Sensor is probably for closed loop
    But without the datasheet you cannot do a lot with it
    You should contact NSK
    They will send you the datasheets
    Sorry for the late reply.
    The first 3 pictures are the drivers. The linear drives themselves are part of the "Megathrust" series and use the "Megatorque" drivers.
    I've reached out to NSK before and got no where...
    https://promshop.info/cataloguespdf/...rustpmandy.pdf
    That may be because I don't really know what I'm looking at. I'm fine with GRBL and arduino based CNCs but that' the limit of my experience.
    I was hoping for a simple STEP/DIR setup
  1. Replies: 0
    Last Post: 17-07-2022, 07:30 PM
  2. Exotic wood. A pleasure to cut.
    By Wal in forum Woodworking Project Showcase
    Last Post: 03-10-2016, 05:13 PM
  3. Difference between exotic material and not exotic
    By hoezap in forum General Discussion
    Last Post: 17-10-2015, 11:56 PM
  4. Replies: 1
    Last Post: 01-07-2014, 07:41 PM
  5. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
