Thread: Homing
    Hi All
    I have my limit switches working but when i hit home on any axis nothing moves what have I missed
    Mike
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    If you're using the same switches for limit and homing, you need to disable the limit function while homing.
    How you do that will depend on what controller/software you're using.
    What controller are you using? Mach3?
    Quote Originally Posted by JohnHaine View Post
    Hi I am using a Mach3 USB Interface Board and Mach 3 Sheen set 2010 to run it. I dont seem to have any power to any axis when press home. what have I missed?
    Mike
    I assume that you can jog so movement is working? The first thing is to check there is homing code behind each button. Which button are you clicking? On my "reference" copy of M3 (on laptop not connected to machine) this is the code behind "REF ALL HOME" on the run screen:
    DoButton( 24 )
    DoButton( 23 )
    DoButton( 22 )
    DoButton( 25 )
    DoOEMButton(133)
    DoOEMButton(134)
    DoOEMButton(135)
    I think those buttons are not linked to any code that causes the machine to move they just zero DROs. To see the code select "edit button script" from the operator menu - buttons with linked scripts will flash - click the one you want to look at.
    Hi is a screen shot of top tool bar. I dont get anything if I click on "edit button script"
    Mike
    Sorry yes all axis are working
    Mike
  1. Mach 3 homing
    By johnboy48 in forum Artsoft Mach (3 & 4)
    Last Post: 25-10-2022, 05:54 PM
  2. About homing and switches...
    By JW1977 in forum General Electronics
    Last Post: 09-09-2019, 09:16 PM
  3. CNC first setup homing
    By Gary1329 in forum General Discussion
    Last Post: 30-07-2019, 11:40 PM
  4. Problem with homing
    By Andyman in forum Gantry/Router Machines & Building
    Last Post: 22-03-2016, 07:56 PM
  5. Homing Switches
    By m_c in forum General Electronics
    Last Post: 04-11-2010, 11:21 PM
