Page 2 of 2 FirstFirst 12
    It says K1 and K2 are the tacho signal ie a DC voltage proportional to speed. I doubt that will be any use with modern drives.
    I have similar SEM motors on my Shizuoka mill with Centroid Acorn controller and drive them with a CNCdrive.com driver. However, these use step/dir for position control so wouldn't be much use to you https://cncdrive.com/downloads/DG4S_series_manual.pdf
    I suspect you might be better off using a modern servo drive that takes a direct (isolated) 0-10V analogue signal among other optional inputs. They can usually be configured for speed or position control. I have used Yaskawa servos previously but also Lichuan servos as suggested by Jazz, which are more cost effective.
    its controlled by Mach 3 via a uc400eth motion controller from memory i bought the Breakout board CP0-10V CNC 4 Axis with Charge Pump and Relay
    Product Code: CP0-10V which supplies the 0-10v
    from cnc 4 you
    ive had this machine a very long time and changed the spindle motor years ago so my memory of the original performance may be confused but i changed it for a reason even if i cant remember it .
    im 90% working with aluminium , cant afford a haas minimill ,so just trying to make the triac the best i can . if everyone else is getting on well with the 4000rpm dc motor where the torque seems to drop off rapidly from 1500rpm the issue might be with me.. as always advice/guidance is welcome
There are currently 14 users browsing this thread. (0 members and 14 guests)
  1. Electric or pneumatic Spindle for stone work ?
    By Fivetide in forum Machine Discussion
    Last Post: 23-07-2021, 01:03 PM
  2. Will this VFD work with this motor?
    By ChrisMe in forum General Electronics
    Last Post: 05-03-2021, 12:48 PM
  3. Replies: 2
    Last Post: 28-02-2021, 10:15 AM
  4. cant get spindle to work with Mach3
    By Bucks in forum Chinese Machines
    Last Post: 01-10-2017, 09:53 PM
  5. Replies: 2
