    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Im looking at this unfinished conversion. (half the NZ dollars to get pounds)
    What do you think ?
    https://www.trademe.co.nz/a/marketpl...ing/4673307048
    Original specs here ;
    http://www.scottmachinery.co.nz/conv...de=MDRL-0-0096
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    Leave well alone IMHO.
    dudz's Avatar
    Haha, ye i thought someone might say that. Could be a can of worms
  1. Sieg/ARC X3 CNC mill conversion
    By Leadhead in forum Workshop & Equipment
    Last Post: 20-10-2018, 04:11 PM
  2. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  3. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  4. CONVERSION: Optimum BF20L Conversion
    By Rikk in forum Conversion Build Logs
    Last Post: 17-07-2011, 06:00 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
