Thread: Breakout boards
Oops! Apologies I inserted the wrong link, the one I'm using has only one relay:
https://www.amazon.co.uk/Fasizi-Brea...dp/B09Z29TYNL/
I don't use the relay anyway.
I see what you mean about the pin confusion The back of the board is more likely to be correct since it shows the PCB legend. Someone has got confused labelling the photo of the front.
If you intend to use the relays not that I don't think they are rated for UK mains voltage - I did need a relay function so use a separate solid-state relay instead.
Recommended breakout boards?
By the great waldo in forum Motor Drivers & ControllersReplies: 0Last Post: 22-11-2017, 09:28 AM -
Some new interesting boards
By Boyan Silyavski in forum Marketplace DiscussionReplies: 19Last Post: 06-10-2017, 05:29 AM -
USB breakout boards from China
By asbo in forum Motor Drivers & ControllersReplies: 0Last Post: 07-10-2013, 01:29 PM -
breakout boards what are you using
By wilfy in forum General ElectronicsReplies: 6Last Post: 01-12-2012, 12:35 PM -
PMINMO 297/298 boards
By irving2008 in forum Motor Drivers & ControllersReplies: 7Last Post: 20-08-2009, 09:02 PM
