  1. #3
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    So I bought the Storebro Combi-mill cnc and converted it to single phase.
    As it is a 1980's machine, the max spindle speed is 2500rpm. Very sturdy little machine weighing around 1.2 tonne. Very capable of milling steel. Has been used by the previous owner for re-boring an engine. So accurate too.
    The Heidenhain 155 controller is great, but in Swedish . Thankfully I have a manual in English.
    As I am used to a home built cnc router with high speed spindle, this one is a learning curve for me.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
  1. eBay: Quick-Step Mill QS 1000 QSM Hemingway kits John Payne, lathe mill head
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 15-10-2018, 12:33 PM
  2. Replies: 3
    Last Post: 28-04-2017, 10:18 PM
  3. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  4. 7' X 4' Combi
    By Ricardoco in forum DIY Plasma Build Logs
    Last Post: 17-04-2013, 01:17 PM
