    Hi
    My 4kw spindle is getting far too hot. The htz are correct at 300htz but I cannot be sure the amps are set correctly on the vfd for that spindle. I'm looking through the manual but i'm not seeing which perameter is for motor amp setup. Anyone familiar with A2 vfd programming?
    Many thanks
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 10 Hours Ago Has been a member for 7-8 years. Has a total post count of 464. Received thanks 74 times, giving thanks to others 21 times.
    The "amps" setting is simply the limit on the maximum current and is intended to protect the motor from overcurrent during overload. More important is to get the speed and voltage correct. Usually you specify the base speed in Hz and the corresponding voltage at that speed (eg 50Hz and 240V for a std online motor in the UK). The VFD will then ensure that the applied voltage is appropriate for the spindle speed. I don't know the A2 but the setup will likely be fairly conventional.
    When you say "far too hot", they are designed to run with an internal hotspot of somewhere between 130C (Class B) and 180C (Class H). Our pain threshold is around 50C, so what may seem "too hot" may be perfectly fine. Have you measured it with a thermometer?
  3. The Following User Says Thank You to Muzzer For This Useful Post:
    First, check the spindle's nameplate for the rated current (usually in Insulated Bearing). For a 4kW spindle, this value is typically in the range of 6 to 9 amps at full load, depending on voltage. Most VFDs have a way to enter programming mode, usually by pressing the “PROG” or “SET” button. Once in programming mode, you can navigate through the parameters.
  1. Vevor 3018 pro
    By Shaggy2023 in forum Chinese Machines
    Last Post: 26-10-2024, 03:34 AM
  2. VEVOR 0.8KW 220V Air Cooled Spindle Motor CNC setup
    By ionapostol in forum Generic Chinese Spindles
    Last Post: 08-08-2023, 08:18 AM
  3. VFD YL620-A2.2KW 220V and 2.2KW water cooled spindle settings
    By A11an in forum Spindles & Drive Motors
    Last Post: 13-12-2020, 07:56 PM
  4. Replies: 17
    Last Post: 11-09-2019, 11:19 PM
  5. Vevor 3020 cnc Autolevelling
    By iBeta in forum Machine Discussion
    Last Post: 22-11-2015, 07:08 PM
