Thread: Mill or Lathe??
    Hi
    I have a problem in trying to work out how to machine slots on the inside of a cylinder?? I'm trying to make a billet clutch basket I have a mill and lathe but my brain cant work it out, the inside diameter is136mm and the slots are 14.5mm wide and 6.8mm high there are 12 to do. Any help would be appreciated
    Dave
Name:	BILLET CLUTCH TWO v5.png
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If the slots need square corners, then they'll need some form of slotting or broaching.
    That could be achieved in a mill or a lathe with a suitable attachment.
    As for the main machining of the cup, a lathe would be most suited, but it all depends on what machines you have available.
    That's a bit awkward,
    Could be done in two pieces and then welded into the assembly, best option would be wire EDM.
    Have a look on you tube, theres a guy who made his own machine and makes some excelent bits and bobs, keyways include.
    You could make the sleeve and broach the keyways but its going to be a two piece assembly.
    something to think about.
    Regards
    Mike
    Another option if you like making tools https://www.youtube.com/watch?v=rTCjC4hmt34
  1. Boxford Duet Lathe Mill
    By johncon69 in forum Boxford Lathes
    Last Post: 05-09-2021, 07:14 PM
  2. WANTED: Boxford Duet CNC Mill and Lathe
    By cosmonat in forum Items Wanted
    Last Post: 18-09-2019, 06:55 PM
  3. eBay: Quick-Step Mill QS 1000 QSM Hemingway kits John Payne, lathe mill head
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 15-10-2018, 12:33 PM
  4. help me buy an er20 collet for my lathe/mill
    By kingcreaky in forum Workshop & Equipment
    Last Post: 13-11-2014, 03:03 AM
  5. NEW MEMBER: New member what to buy ?? mill and lathe
    By funni in forum New Member Introductions
    Last Post: 25-11-2009, 02:33 PM
