    Hi, Could anyone please give me a bit of guidance. My CNC is becoming unpredictable.Yesterday it stopped, saying there was an external stop pressed when there was no-one near it or even in the workshop. Then I sent it to home and tried to home it but it just slowly crept down towards the spoilboard. I had to stop it. I tried several times to home it but ended up turning it off. It was also cutting deeper with different tool paths when they should have been the same. I stopped using the z sensor device and started using a piece of paper to set z,
    Today - completely different file. I set the Z using a piece of paper. Half way through a sign it started cutting much deeper. It had already cut a good bit perfectly. It also didn’t lift properly between cuts and scraped across the wood.
    The z flow is regular without any hiccups and it moves in every direction smoothly. The machine looks and feels as solid as a rock. I suspect software but I don’t know what.
    Can anyone please tell me what I should be looking for.
    Thanks.Click image for larger version.
    Last edited by BruceR; 23-08-2024 at 04:07 PM. Reason: Picture of spoilboard added
  1. Replies: 10
    Last Post: 14-02-2018, 12:45 AM
  2. Replies: 0
  3. Replies: 46
    Last Post: 26-04-2016, 12:06 AM
  4. Cutting deeper in areas???
    By alboy in forum Gantry/Router Machines & Building
    Last Post: 29-01-2015, 05:54 PM
  5. Replies: 0
