    Hi
    I'm new to the forum and i hope its ok to ask for help!
    I purchased a second hand axyz 6010 cnc with atc and icut software for contour cutting.
    We have tried uninstalling and reinstalling the software for the icut but are running into issues. Please see attached and help / advice would be greatly appreciated
ID:	32349Click image for larger version.
ID:	32350Click image for larger version.
    There are several other threads about the battle to get an AXYZ machine running.Take a bit of time and read them.
    First of all you need to get that RS485 working correctly or you won't be able to send the programme to the controller.The computer isn't necessary once the programme has been loaded into the controller as the files can be selected and run from the console.
    Have you used a CNC router before?Do you have experience of using icut?
  3. The Following User Says Thank You to routerdriver For This Useful Post:
    Quote Originally Posted by routerdriver View Post
    Hi thanks for your reply. Yes we have always run gerber machines before though - still run a 408 on a daily basis.
    We have no experience in using the icut though. The machine itself is working fine apart from the atc which axyz are coming to fix hopefully.
  5. #4
    My increasingly distant recollection of the AXYZ controller is telling me that there may well be a command that needs to be executed to activate the ATC.If you have the manual for the machine,it will be in there -F30somethig I believe.I hope you have enough information to get the machine working,but be sure to learn the quirky system of setting spoilboard height and material surface before cutting anything.It could mean a new spoilboard if you don't get it right.
  6. The Following User Says Thank You to routerdriver For This Useful Post:
  1. FOR SALE: FOR SALE - AXYZ Infinite 6010 CNC Router (2020)
    By Tallon Associates in forum Items For Sale
    Last Post: 25-05-2021, 10:15 AM
  2. Used Axyz 6010 ATC for sale
    By jimmy zenon in forum AXYZ Routers
    Last Post: 17-05-2020, 06:26 PM
  3. AXYZ 6010 3x2 meters Great condition, Must See!!!
    By adamwojtowicz in forum Classified Ads, Buy, Sell & Swap
    Last Post: 03-01-2015, 05:39 PM
  4. Reversed axis on a AXYZ 6010 after installing DNC controller software...
    By RickyThunders in forum Machine Control Software
    Last Post: 12-02-2013, 03:56 AM
  5. FOR SALE: AXYZ 6010 CNC Router for sale
    By Rallyingmick in forum Items For Sale
    Last Post: 12-04-2012, 05:34 PM
