Thread: LinuxCNC
    Chaz's Avatar
    Hi, I've avoided Linux CNC due to the assumed time sink into getting it understood / learnt and configured.
    That said, once I can get my head around what controller to use (Mesa, so many options), it looks very powerful and one of the few cheaper ways to get 5 Axis RTCP without paying >£1K for a controller.
    I'm thinking about trying a setup on my little boxford dueti Lathe / Mill. Ill focus on the lathe part, need a Y axis for tooloffsets. Any idea where to start in terms of controllers?
    I was looking at the Mesa 7i96s - is this all I need for 3 axis and spindle speed input with the usual end stops / limits etc?
    Lives in East Lothian, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I dabbled in LCNC last year.
    7i96 will give enough basic functionality for most machines, the S version adds the expansion port required for daughter cards.
    Chaz's Avatar
    Thanks. When do we need additional cards? Will the one I referred to do basic 3 axis step dir, 0 to 10v for spindle and encoder spindle input?
    When you run out of inputs/outputs.
    I never went the Mesa route, as I was playing with some EtherCAT drives, but discovered a major show stopping bug, which nobody knew the cause off, or how to fix, so those drives/motors are still sat unused on the shelf.
    Chaz's Avatar
    Thanks.
    The kit you have, does it do step / direction too? If so, would you consider selling it for me to try and use (not in Ethercat mode)?
    No, they're EtherCAT only, and the other two non-EtherCAT sets I've got lying around are destined for machines.
  7. The Following User Says Thank You to m_c For This Useful Post:
  1. Triac PC Linuxcnc
    By JohnT in forum Denford Mills
    Last Post: 29-07-2022, 09:47 PM
  2. Mach3/Linuxcnc
    By jolyonjenkins in forum Machine Control Software
    Last Post: 02-08-2020, 11:01 PM
  3. Replies: 12
    Last Post: 24-04-2020, 11:01 AM
  4. NEW MEMBER: LinuxCNC using EtherCAT anyone doing this?
    By Brassneck in forum New Member Introductions
    Last Post: 01-08-2019, 11:12 AM
  5. What do I need to run LinuxCNC???
    By gatesy in forum LinuxCNC (EMC)
    Last Post: 02-12-2015, 07:42 PM
