    JBL_LG's Avatar
    Lives in Trzcinica, Poland. Last Activity: 3 Weeks Ago Has been a member for 4-5 years. Has a total post count of 20.
    Hello.
    Voltage measurement value on the THC 150 screen changes. In the Mach3 torch control interface, the torch changes height. However, this is practically imperceptible to the user and when the torch is too close to the sheet metal, it shuts down.
    All outputs (ARC, DWN, UP) are connected to the AXBB-E isolated inputs together with the power pins. The measurement terminals marked 'Plasma Voltage' on the chassis are connected to the electrode, material and plasma source. I am using Mach3 software with the AXBB-E plugin installed.
    What else needs to be tweaked in the controller, material position or Mach3 for it to cut without problems?
    Sounds like a leak to me (interference perhaps?), check all your earth (ground) wires are secure, make sure no control and power wires are in close proximity to each other...
    Plasma machines are notorious for needing a good solid earth/grounding electrically they're super noisy. Hopefully someone else has a better input for you :)
  1. NEW MEMBER: New to CAD, looking for help in getting started cutting CF sheet
    By Devil_WAH in forum New Member Introductions
    Last Post: 23-02-2017, 07:30 PM
  2. FOR SALE: Sheet Metal Roller.
    By Palmers Tech in forum Items For Sale
    Last Post: 06-02-2017, 12:45 PM
  3. Replies: 1
    Last Post: 01-02-2017, 01:14 PM
  4. Sheet support for a plasma machine?
    Last Post: 10-02-2014, 08:44 PM
  5. Cutting metal shapes
    By jmac80 in forum Metalwork Discussion
    Last Post: 27-11-2013, 10:32 PM
