Hi All
First post so be gentle :-)
I have a MM32L that I have just done a spindle motor conversion on using a 3.6KW servo. I have upped the RPM from 2200rpm to 5000rpm and as you might imagine my bearings are getting a little hot. I have identified and ordered suitable high quality replacements for the quill drive so I then decided to have a peak in the main spindle body (looks a lot like a PM30 spindle)
I was expecting to see taper roller bearings but I see what I think are angular contact bearings. Has anyone else had experience of this machine and can confirm this. I am thinking I might just be able to re-pack them with the right amount of klubber grease and they would be good to go?
Attached are a couple of the bearing and the motor conversion.
ID:	32413Click image for larger version.
