    Hi, I am trying to convert a milling machine to cnc. I am using a centroid acorn break out board. So far I have got one of the three stepper motors working fine. However one motor is only moving slowly and the other not at all, its locked up but not moving.
    My questions are. Is this due to wrong switch set up on the stepper driver, the three stepper drivers are different. I know not the best idea, but it's what I had. Or is the slow and none moving motors down to lack of power. I have two power supplys feeding the drivers, both rated at 24volts.
    Within the software all motors are set up the same.
    Any one any ideas. Thanks
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by terry1956 View Post
    Some pictures would help. Also have you set the steps per the same for each motor. Have you wired the enable to the drives as a lot of drives work the opposite . etc.
  1. Reverse stepper motor direction on driver/motor winding
    By Nemo1966 in forum General Discussion
    Last Post: 07-08-2024, 03:25 PM
  2. Motor problems/
    By erniehatt in forum Stepper & Servo Motors
    Last Post: 30-12-2021, 05:49 AM
  3. stepper driver problems
    By Arzo10 in forum General Discussion
    Last Post: 05-03-2017, 04:13 PM
  4. Replies: 1
  5. slaved stepper problems
    By johngoodrich in forum Stepper & Servo Motors
    Last Post: 11-07-2012, 07:00 PM
