    I have 2 BSMCEO4U boards both boards won't work with MACH3. They work with Drufel CNC software fine but I don't have a license for Drufel. I tried everything but I can't connect the board to MACH3. I added the RnR dll and the config XML to the installation folder but still it gives me error "RnR motion card not found". Can anyone help please ? I am using windows 11.
    I suggest you ask over on the Mach 3 forum.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    My guess is that the driver (DLL) isn't security signed, so won't work with Windows 11.
    If you look in Device Manager, does the card show when plugged in, and does it show as having any errors?
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #4
    Thanks for the reply. I checked device manager multiple times and it's not showing up. When I plug it in however I can hear the new device added sound and no error messages telling me device is unrecognizable. This leads me to believe that it's working fine . If it's due to the DLL not being security signed what do I do then ?
  6. #5
    Unfortunately, although I do have a Win11 laptop, I don't use it that much, and I've certainly not yet had any reason to look at how the device manager shows unrecognised devices.
    If the driver isn't signed, then you're probably looking at another PC/laptop running an older version of Windows.
    I know there was a way to disable the requirement for signed drivers with Win10, however I'm not sure that option exists for Win11, and it was a bit of a pain to implement.
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #6
    How much older ? Are we talking windows 7 or something even older than that ? Thanks again for the help.
  9. #7
    I've just realised you mentioned that the cards do work with Druful, so the drivers must be fine.
    The issue is possibly a more generic Mach3 issue, as Win11 may reject certain DLLs if it think that they're suspicious.
    Win10 should be old enough, but is there anybody you could borrow a PC/Laptop from to try?
  10. The Following User Says Thank You to m_c For This Useful Post:
  11. #8
    You were correct bud. I did a dual boot of windows 10 & 11, Just tested it on windows 10 and it works fine. Thanks a lot man.
  12. #9
    Quote Originally Posted by Fancy View Post
    Excellent, what will you be making first?
    Nothing too exciting :D Just a waste board, But you will be seeing much more of me. I am planning on doing an epoxy granite mill build. The machine I got now is a just a beefed up version of OX CNC so I don't expect much out of it. I am planning on doing some light prototyping on it.
  1. Breakout board bsmceo4u-pp
    By Bruce H in forum Machine Discussion
    Last Post: 11-12-2020, 03:10 AM
  2. Mach3 and JK02-N breakout board
    By JimK in forum CNCdrive (UC100, UC300ETH)
    Last Post: 18-08-2019, 01:06 PM
  3. Help connecting servos to breakout board Mach3
    By Agathon in forum Stepper & Servo Motors
    Last Post: 02-09-2017, 04:19 PM
  4. Spindle2 board Mach3 set up
    By Simon C in forum Motor Drivers & Controllers
    Last Post: 05-06-2011, 02:11 PM
  5. can mach3 burnout transistors on a CNC control board?
    By kevinb in forum Artsoft Mach (3 & 4)
    Last Post: 29-11-2010, 04:24 AM
