Thread: Reamer sizing
    Hi there,
    This is my first post so apologies if it's not in the right place.
    I would like to fit a 11mm id x 5 od x 5W bearing into a 11mm ish hole in brass. I am looking for an interference fit and intend to use a press or a vice to fit the bearing.
    The question is what size reamer to use?
    As far as i can figure out i should be looking at 0.0127mm to 0.0203mm (0.0005 to 0.0008") for clearance. So I am thinking of drilling to 10.9mm then using either a 10.99mm or 10.98mm reamer, all on a lathe.
    Any advice would be greatly appreciated.
    Mark.
    You'd have to use a machine reamer and would be lucky to get the fit you want. I'd bore the hole myself and use bearing lock rather than a press fit.
  1. Getting the sizing right
    By Mark121 in forum Woodwork Discussion
    Last Post: 12-06-2022, 12:16 AM
  2. rdgtools expanding reamer
    By mekanik in forum Workshop & Equipment
    Last Post: 14-10-2020, 07:33 PM
  3. Dowel holes reamer or interpolation?
    By hoezap in forum Metalwork Discussion
    Last Post: 10-04-2016, 12:44 AM
  4. Vintage Dormer Twist Drill and Reamer Information Handbook
    By Wal in forum Tool & Tooling Technology
    Last Post: 18-12-2015, 03:27 PM
  5. WANTED: 8mm Reamer
    By Jonathan in forum Items Wanted
    Last Post: 13-04-2011, 04:43 PM
