    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 4 Weeks Ago Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Using my Storebro Combi-mill, (top spindle rpm 2500) - 1980s cnc mill
    Just looking forward into situations I'm bound to find myself in....
    For contour passes, I use 3 flute 10mm dia endmills (25mm usable cutting edge) full doc, 3mm stepover for roughing down, then to 0.2 on finishing passes. The finish has been very good. I could prob go double the stepover but haven't had the machine long enough to test it properly.
    using 2D contour passes in fusion, I would like to know if its best to use a large dia endmill to rough the contour passes down. I wondering if I can get away with a 20mm dia ( 50mm long flute ) 35mm doc then go in with a 10mm dia for finishing passes.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
There are currently 13 users browsing this thread. (0 members and 13 guests)
  1. NEW MEMBER: Jumping in at the deep end
    By TimB in forum New Member Introductions
    Last Post: 01-04-2023, 11:37 PM
  2. Deep Slot Milling in Aluminium - Optimum Cutter Diameter
    By guy_ in forum Metalwork Discussion
    Last Post: 03-04-2021, 12:09 PM
  3. Outer cut cutting too deep
    By scapaflyer in forum Rails, Guideways & Bearings
    Last Post: 04-04-2018, 07:42 AM
  4. 4.3 mm holes, 20 mm deep
    By Chaz in forum Metalwork Discussion
    Last Post: 08-08-2017, 10:46 PM
  5. How deep can i cut MDF?
    By MrWiz73 in forum Machine Discussion
    Last Post: 24-08-2011, 10:38 PM
