    I need to reduce rapid speed for all axes (X, Y & Z) from machine parameters of Mikron HSM 700. When it is moving maximum speed (5000), it having abnormal sound. I repaired X & Y screws week a go. There is no any noise when it moving slow speed.
    Thanks,
    Adikari
  2. The Following User Says Thank You to Adikarinu For This Useful Post:
  3. #2
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 14 Hours Ago Has been a member for 8-9 years. Has a total post count of 474. Received thanks 76 times, giving thanks to others 24 times.
    You might want to give a bit more information such as what machine and controller you have. Also, what is the question - are you not sure where to make the changes?
    Machine is Mikron 700 and control system is Heidenhain Atek (HS Plus). When I am doing a Job, I reduce rapid speed from manually from potencial meter. But I need to reduce from Machine system parameter, Then I don't want to concentrate rapid speed allways.
  5. #4
    Hi.
    Please send me your contact details (WhatsApp,email)
    Thank you
    Chandana Nuwan
  1. Rapid Change ATC
    By AndyUK in forum Tool & Tooling Technology
    Last Post: 14-01-2024, 12:14 AM
  2. Treadmill motor is 180V DC, how can I reduce voltage from 240v?
    By craigrobbo in forum Sieg Milling Machines
    Last Post: 16-12-2023, 12:18 PM
  3. External Toggle Switch For Slow / Rapid Jog Speed
    By mondrota in forum Programmers Corner
    Last Post: 02-07-2020, 04:30 PM
  4. Refitting ZAxis stepper to reduce height
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 03-06-2015, 10:07 PM
  5. No rapid overide on Mach3
    By GeoffV in forum Artsoft Mach (3 & 4)
    Last Post: 18-11-2010, 04:52 PM
