05-02-2025 #1
So it will be the first time I am going to mill steel on my CNC mill. Firstly, The mill is 1980's. It weighs 1.1 Ton / Max Spindle Rpm 2500 / 2.2kw motor. I am using Fusion 360.
I have a 20mm thick piece of mild steel. I want to face it down to 12mm. I have a 5 flute 50mm Shell mill with carbide inserts. I have used it on aluminium with different inserts for ali with good results. Online calculators don't seem to give me a very good starting point for this shell mill.
What doc could I take without pushing the tool to hard ?. Speeds and feeds would be helpful to the relative docLast edited by dudz; 06-02-2025 at 08:18 AM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
Working with mild steel.
By Wal in forum Metalwork DiscussionReplies: 9Last Post: 19-09-2020, 04:35 PM -
RFQ: Large bed CNC Mild Steel (500 x 500 x 50)
By Jono in forum Projects, Jobs & RequestsReplies: 0Last Post: 03-04-2017, 05:05 PM -
Where to get Mild Steel Plate?
By Chaz in forum Marketplace DiscussionReplies: 33Last Post: 03-01-2017, 01:17 PM -
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM
