    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I have an alpha 025 hss cse-25 countersink bit. (3 flutes)
    I tried for the first time today, pushing it into a 12mm dia through hole in mild steel on the cnc mill. I used 250rpm (my cnc mill lowest rpm). Surface speed of 20m/min - plunge rate of 64mm/min . That's what fusion through out. I'm using flood coolant
    I pulled it up half way on each hole to remove swarf and continued. Ok until I got 2/3rds of the way in. It sounded like it was rubbing - then pushed up further into the ER32 collet and span in the collet. Now got to order a new collet.
    Was I way out on the feeds/speeds ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 21 Hours Ago Has been a member for 8-9 years. Has a total post count of 492. Received thanks 82 times, giving thanks to others 27 times.
    That's a plunge rate of >1mm per second. That might be ok for the first mm or so but with a countersink, the spindle load increases proportional to the depth.
    When countersinking (chamfering) a hole under CNC control, I always run the tool around the hole, using it as a milling cutter rather than a countersink. And rather than use a large 25mm countersink tool, I'd use a smaller (eg 6mm) chamfer mill. For a hole that isn't close to any vertical features that might interfere, you could still use the large countersink but I'd recommend using a profile toolpath rather than a drill cycle.
    When generating a chamfer (actually 2D profile) toolpath in Fusion, you either model the feature without the chamfer then add the chamfer in CAM - or you model the chamfer and run the chamfer toolpath in CAM (2D profile etc) without any additional chamfer "depth" programmed.
    Like this:
  3. The Following User Says Thank You to Muzzer For This Useful Post:
    dudz's Avatar
    Nice, sounds the way to go. After I thought of boring the countersink hole with a 10mm carbide endmill at 0.5mm step-downs so most of the material is gone then using the countersink bit, which prob would have been much kinder on my cnc. But your way seems a huge improvement on that. The countersink had to be around 10mm deep, so the full flute of the 25mm tool had to be in the hole.
There are currently 19 users browsing this thread. (0 members and 19 guests)
  1. FOR SALE: 20mm and 25mm INA and THK carriages and some rail.
    By Nealieboyee in forum Items For Sale
    Last Post: 17-02-2020, 09:06 PM
  2. RFQ: 25mm plywood parts
    By eurikain in forum Projects, Jobs & Requests
    Last Post: 03-09-2015, 01:13 PM
  3. Routing with 25mm pine
    By marsheppard in forum Woodwork Discussion
    Last Post: 12-05-2013, 07:46 PM
  4. Countersink Cutter Feed & Speeds
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 01-02-2013, 09:34 PM
  5. FOR SALE: Dormer A002 Jobber Drills, Dormer E500 Taps & Countersink Bit
    By mikey in forum Items For Sale
    Last Post: 06-10-2012, 11:45 PM
