    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I have an alpha 025 hss cse-25 countersink bit. (3 flutes)
    I tried for the first time today, pushing it into a 12mm dia through hole in mild steel on the cnc mill. I used 250rpm (my cnc mill lowest rpm). Surface speed of 20m/min - plunge rate of 64mm/min . That's what fusion through out. I'm using flood coolant
    I pulled it up half way on each hole to remove swarf and continued. Ok until I got 2/3rds of the way in. It sounded like it was rubbing - then pushed up further into the ER32 collet and span in the collet. Now got to order a new collet.
    Was I way out on the feeds/speeds ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    That's a plunge rate of >1mm per second. That might be ok for the first mm or so but with a countersink, the spindle load increases proportional to the depth.
    When countersinking (chamfering) a hole under CNC control, I always run the tool around the hole, using it as a milling cutter rather than a countersink. And rather than use a large 25mm countersink tool, I'd use a smaller (eg 6mm) chamfer mill. For a hole that isn't close to any vertical features that might interfere, you could still use the large countersink but I'd recommend using a profile toolpath rather than a drill cycle.
    When generating a chamfer (actually 2D profile) toolpath in Fusion, you either model the feature without the chamfer then add the chamfer in CAM - or you model the chamfer and run the chamfer toolpath in CAM (2D profile etc) without any additional chamfer "depth" programmed.
    Like this:
  3. The Following User Says Thank You to Muzzer For This Useful Post:
    dudz's Avatar
    Nice, sounds the way to go. After I thought of boring the countersink hole with a 10mm carbide endmill at 0.5mm step-downs so most of the material is gone then using the countersink bit, which prob would have been much kinder on my cnc. But your way seems a huge improvement on that. The countersink had to be around 10mm deep, so the full flute of the 25mm tool had to be in the hole.
  1. FOR SALE: 20mm and 25mm INA and THK carriages and some rail.
    By Nealieboyee in forum Items For Sale
    Last Post: 17-02-2020, 09:06 PM
  2. RFQ: 25mm plywood parts
    By eurikain in forum Projects, Jobs & Requests
    Last Post: 03-09-2015, 01:13 PM
  3. Routing with 25mm pine
    By marsheppard in forum Woodwork Discussion
    Last Post: 12-05-2013, 07:46 PM
  4. Countersink Cutter Feed & Speeds
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 01-02-2013, 09:34 PM
  5. FOR SALE: Dormer A002 Jobber Drills, Dormer E500 Taps & Countersink Bit
    By mikey in forum Items For Sale
    Last Post: 06-10-2012, 11:45 PM
