13-03-2025 #2
I've only had a quick look, but the following things stand out-
- Shouldn't the push button lamp be connected to an output? (You'd ideally want some code so the button only illuminates when it's active)
- You have S1 and S2 twice (going by the fact they have 24V and 0V connections, I'm guessing these are inductive sensors, so you'll need to check how the output switches, but each will only need a single input)
- Is the temperature sensor a switch, or a thermistor? (I've not searched for a manual, but going by it having two wires, and there being a separate thermal switch on the power connector, I'm guessing it's a thermistor, in which case you'd need an analogue input to make use of it in the software)Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
There are currently 64 users browsing this thread. (0 members and 64 guests)
UC300ETH: UCBB Vs UB1 breakout board ?
By routercnc in forum CNCdrive (UC100, UC300ETH)Replies: 28Last Post: 31-08-2021, 12:38 AM -
BUILD LOG: uc300eth/ub1 wiring advice needed
By Gav74 in forum DIY Router Build LogsReplies: 3Last Post: 01-01-2020, 12:13 PM -
Uc300eth-5lpt overheating precautions
By jtar40 in forum General DiscussionReplies: 9Last Post: 01-08-2019, 02:04 PM -
UC300eth UB1 wiring help.
By Nickhofen in forum General ElectronicsReplies: 3Last Post: 05-09-2018, 09:12 PM -
FOR SALE: Uc300eth ub1
By Web Goblin in forum Items For SaleReplies: 6Last Post: 18-03-2018, 11:58 AM
