Thread: ATC Push Button
18-04-2025 #1
Hello again,
I have my ATC manual Tool Change Push Button from my Spindle connected to my UCBB Inputs, none of the Input LED's are on until I press the Spindle Button, then the LED on the UCBB lights up (see image, of wiring and LED lit) it stays on until I release it, which I think is how it should work...? What I don't understand is how to get the Solenoid to activate, I have two relays wired in to my Outputs with Solenoids attached to them and I have these working with a Test Macro but how do the Inputs communicate with the Outputs, is there something I need to configure or is it a physical wire from the input to the Relay or something...?
ATC Push Button.pdf
Cheers,
Phil
20-04-2025 #2
hi phil just seen your message ,havent been on for a while ,,if you goto settings , i/o trigger , output trigger ,enter your input port and pin then in the set field select your output port and pin apply the settings ,,, the push button connected to the input should now trigger the output and activate the solenoid , check or uncheck the low box to suit
The Following User Says Thank You to voyager1972 For This Useful Post:
21-04-2025 #3
Ahhh that's great, thanks for that. I'm on Holiday at the minute but I'll give that a go when I'm back, thank you
22-04-2025 #4
you can also use the input output triggers to disable the spindle pushbutton relay for safety so you cant eject the tool during cutting ,,,enter the port and pin numbers you have set for spindle cw and ccw and set the port and pin for the pushbutton so that it disables the relay when an m3 or m4 is run
22-04-2025 #5
03-05-2025 #6
Brilliant. I've just tested the input/output triggers, and thanks to you, Voyager, I've got it working. I will look at the disabled push button safety feature at a later date. I don't have my Spindle going CCW, only CW.
Now, I need to finish wiring the Limit Sensors and Probes, and I should be able to start full testing.
Thanks very much!!
Phil
Mach 3 - Mapping to Zero X, Y and Z via Hotkeys / Push Button (Ger's Screenset 2010)
By Chaz in forum Machine Control SoftwareReplies: 2Last Post: 14-07-2018, 08:55 PM -
Ready to push the button and buy a laser....
By Davek0974 in forum Laser Machines & BuildingReplies: 77Last Post: 08-09-2017, 11:36 AM -
Please don't push 14A through that PCB !!!
By Jonathan in forum General ElectronicsReplies: 9Last Post: 05-01-2017, 04:43 PM -
FREE: Green/Red/Black 3P push button rocker switches
By Lee Roberts in forum Classified Ads, Buy, Sell & SwapReplies: 3Last Post: 08-05-2016, 07:38 AM -
push down plate,
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 31-07-2013, 11:38 PM
