    Hello,
    I'm selling parts of my CNC which I built in 2015 with several posts on this forum.
    It worked like a charm but took too much room so I dismantled it in 2017.
    Main parts:
    - 2 x rail SBR20 1300mm
    - 2 x rail SBR20 2000mm
    - 2 x rail SBR20 600mm
    - 1 x ball screw SFU1605 1300mm
    - 1 x ball screw SFU2005 2000mm
    - 1 x ball screw SFU2005 350mm
    - 12 x SBR20UU supports
    - 4 x Nema 23 450 oz-inch pre wired for my control box
    - 1 x Huanyung FVD PD002 220V 2.2kw spindle with VFD
    - water pump + tubing that goes with it
    Control box:
    - architecture and discussions around it here: https://www.mycncuk.com/threads/9333...-Diagram-check
    - pictures I posted a couple years ago: https://www.mycncuk.com/threads/9333...2813#post82813
    - it contains a printed diagram of fuses (latest revision)
    - it contains a printed wiring diagram (latest revision)
    - wiring diagram, but I posted it here a few years ago: https://www.mycncuk.com/threads/9333...5861#post75861 (not sure it's the latest revision)
    - QElectrotech wiring diagram (not sure it's the latest revision): qet-files.zip
    The electronics inside:
    - 5 axis breakout board compatible with Mach 3
    - 4 x stepper driver AM882
    - 70V 10A linear power supply
    - 24V power supply
    - 5V power supply
    - homing touch probe
    - E-Stop
    - master switch
    - fans switch
    - limit switch override switch
    - reset
    - limit switches buzzer
    - fuses for all power supplies, VFD and water pump
    - plugs for all axes, water pump, limit switches, computer...
    Accessories:
    - a bunch of carbide end mills (2-6mm, 6mm x 32mmn, shaving, ball, carving...)
    - a bunch of switches, mechanical limit switches, proximity limit switches, connectors, relays, fuse housings
    - a bunch of meters of wiring
    - printer port cable for the 5 axis breakout board
    - a few extra stepper motor couplers
    Price: make offer
    Shipping: I honestly don't know how I could pack all this to send it to you, I'd have to research a bit. That said, if you're in the UK, you might just come pick it up as I'm in Belgium. Must be discussed.
    I'm available via WhatsApp at +32488272001
    A bunch of pictures attached.
    Wishing you a very good day !
ID:	32558   Click image for larger version.
ID:	32557   Click image for larger version.
ID:	32556   Click image for larger version.
ID:	32555   Click image for larger version.
ID:	32554   Click image for larger version.
ID:	32553   Click image for larger version.
ID:	32559   Click image for larger version.
ID:	32560   Click image for larger version.
ID:	32561   Click image for larger version.
ID:	32563   Click image for larger version.
ID:	32564   Click image for larger version.
ID:	32565   Click image for larger version.
ID:	32566   Click image for larger version.
ID:	32567   Click image for larger version.
ID:	32568   Click image for larger version.
ID:	32569   Click image for larger version.
    Everything has been sold. I don't know how to delete this post.
  1. EXPERIENCE: Re Buying linear rails and ball screws from BSTmotion/Automation
    By Crunch in forum Trading Experience & Feedback
    Last Post: 06-07-2019, 04:58 PM
  2. Where to buy linear rails & ball screws
    By bluesking in forum Marketplace Discussion
    Last Post: 26-04-2019, 11:48 AM
  3. WANTED: SORTED : light-weight rails & screws (ball/trapezoidal)
    By Doddy in forum Items Wanted
    Last Post: 31-03-2016, 06:24 PM
  4. Replies: 1
    Last Post: 01-07-2014, 07:41 PM
  5. FOR SALE: rails, screws, bearings and spindle
    By wilfy in forum Items For Sale
    Last Post: 10-04-2013, 01:50 AM
