    Hi all
    Usually I would go to kjn ,for one their local but it seems their range is a bit lacking when it comes to large profile, i've been trawling the web looking for large c-beam extrusion but everything I am coming across is 4080
    Does anyone know of a uk supplier with a decent range of c-beam id like something around 160mmx80mm or thereabouts, 4080 is way too small for my job
    Anywhere on line UK i should be looking at? thanks
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I did have a list of with some UK suppliers from when I was looking at building a router, but I can't find it.
    Only thing I can find, is the model I started on used a Kanya 50x100 extrusion - https://www.kanya.com/en/products/ex...02-02-200.html
    Thanks mc
    It does need to be c-beam really, if i have no choice then i,ll have to have a rethink but i'm sure i saw big stuff somewhere, a while back, now all i can find 4080 in light/heavy or anodised,Thanks for the reply.
  5. #4
    dazza
    after trying loads of different remedies to the c beam twist on my cnc i ended up opting for the below from valder for my x axis.
    https://vallder.com/product/cnc-x-ax...rofile-200x96/
    it lead to a massive change in end plates, ball screws etc but ws well worth it.
  6. #5
    Thanks pal
    That looks ideal for what I need I will have a close look at that.
    I just need to fit two rails and a rack and pinion to it.
  1. C Beam extrusion V wheels tight
    By Daveo in forum Rails, Guideways & Bearings
    Last Post: 24-05-2020, 10:28 PM
  2. BUILD LOG: Aluminium Extrusion Question
    By PuppyWoofie in forum DIY Router Build Logs
    Last Post: 13-11-2012, 02:19 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. Aluminium Extrusion suppliers?
    By m_c in forum General Discussion
    Last Post: 12-04-2011, 01:23 AM
  5. Tapping Aluminium extrusion
    By Web Goblin in forum Metalwork Discussion
    Last Post: 03-01-2011, 03:13 PM
