Page 1 of 3 123 LastLast
    I've been wanting to do this project for a while. I wondered if it would be possible to build a spindle monitor to check if it has stalled out and then e-stop. Hopefully this would stop it breaking end mills. Sounds easy in principle . . .
  2. The Following User Says Thank You to routercnc For This Useful Post:
  3. #2
    I would exxpect the VFD to have a motor stall function in it's parameters, the ABB one I use certainly has although I have not tested it in practice.
    Maybe but I've not found it in the 'documentation'. Would simplify things if it did.
  5. #4
    Episode 2, just making it better all round . . .
  6. #5
    These inverter parameters look interesting;
    PD118, PD119, PD120, PD121, PD122, PD123, PD124, PD125
  7. #6
    Reading them now. Looks interesting! Worth experimenting with to see if it really can detect a stall through current monitoring and then trip the onboard relay (although I think that is omitted on my model, although I might be mixing it up with the inverter inspection I did for the drill press project)
    External current monitoring did not seem to show much but maybe internally it is reading a different part of the circuit.
    Might turn out to be the biggest waste of time project (except for the fun and learning)
  8. #7
    I decided to look into the inverter parameters . . .
  9. #8
    Prototype PCB!
  10. #9
    More developments, some hardware but mostly software including storing user values in non-volatile memory. Also a look ahead to the next PCB revision . . .
  11. #10
    New PCB boards to split the LCD display and the processor. Went smoothly apart from the bits that didn't.
  1. X Axis Stall
    By AndyW in forum Machine Discussion
    Last Post: 09-10-2021, 09:33 PM
  2. MACH3 hitting soft limits causes X axis to stall
    By STK2008 in forum Milling Machines, Builds & Conversions
    Last Post: 28-09-2020, 03:44 PM
  3. stepper motor stall?
    By mancave newby in forum Machine Discussion
    Last Post: 22-06-2018, 06:59 PM
  4. em806 Senssorless Stall Protection fault
    By charlieuk in forum Motor Drivers & Controllers
    Last Post: 15-11-2017, 11:36 PM
  5. Digital Drivers and Stall Detection
    By Washout in forum Motor Drivers & Controllers
    Last Post: 10-12-2013, 05:02 PM
