Thread: DIY spindle stall monitor
3 Days Ago #21
Finally finished. We needed to strip down some of the machine to route the wiring, then it was time to upload all the information to GitHub.
1 Day Ago #22
I'm a bit bemused by this. In my experience of breaking cutters the spindle has never stalled, if it had the cutter might not have broken! The last one I broke I made a mistake setting Z height and the machine made a rapid move straight down into the work, fortunately not through the spoil plate. The spindle carried on regardless! Am I missing something?
16 Hours Ago #23
Cutting 1000 grade thin sheet tend to gum up the cutter. It’s almost pure aluminium. Then it stops cutting and the spindle stalls and the end mill breaks. 6061 alum alloy is better but if the bit gets hot again it can gum up. Mist or flood cooling minimises this risk but it gets messy.
15 Hours Ago #24
Well, I'm still bemused. If it's the cutter that stalls the spindle then it has to take all the momentum of the spindle to stop it so the instantaneous torque on the cutter must be much larger than the motor torque. As I said The motor hasn't stalled any time I've broken a cutter. Anyway it will be good to hear of your experience with the system - will you be doing some controlled experiments?
X Axis Stall
By AndyW in forum Machine DiscussionReplies: 10Last Post: 09-10-2021, 09:33 PM -
MACH3 hitting soft limits causes X axis to stall
By STK2008 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 28-09-2020, 03:44 PM -
stepper motor stall?
By mancave newby in forum Machine DiscussionReplies: 12Last Post: 22-06-2018, 06:59 PM -
em806 Senssorless Stall Protection fault
By charlieuk in forum Motor Drivers & ControllersReplies: 19Last Post: 15-11-2017, 11:36 PM -
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM
