    Hi, I have a router with a motor on each side on the y axis. How do I wire these to work together. I am connecting to a cs-labs motion controller.
    dh42's Avatar
    Lives in Sorbiers, France. Last Activity: 3 Hours Ago Has been a member for 0-1 years. Has a total post count of 14. Received thanks 4 times, giving thanks to others 0 times.
    Hello,
    There is 2 ways:
    1) You can use Y and A axis output and set them as "slave" in Mach3 to "link" the both axis; in this case, of course both axis must have the same settings (steps/per, accel, velocity, etc) This method allow you to use the "squaring" features of Mach3 (double homing)
    2) You can use only the Y axis output to drive the 2 drivers ; in this case you save an output for another usage and you limit the risks of one motor losing steps and shifting in relation to the other. Off course in this case the "squaring" can't be used.
    The CS Lab motion controler can also have its own settings ; this is card that I don't know very well.
    David
  3. The Following User Says Thank You to dh42 For This Useful Post:
    Thanks David, just what I needed
  1. 5 phase nema 23 size motors and controller one 3 axis one 4 axis
    By nobby in forum Classified Ads, Buy, Sell & Swap
    Last Post: 05-02-2023, 05:43 PM
  2. Correct wire size for servo/stepper motors ? Dummy question
    By the great waldo in forum General Electronics
    Last Post: 17-10-2021, 05:55 PM
  3. Correct wire for stepper motors??
    By RocketBoy in forum General Electronics
    Last Post: 05-07-2016, 10:54 PM
  4. What gauge wire for motors and drivers etc?
    By glynster in forum Gantry/Router Machines & Building
    Last Post: 01-03-2015, 01:40 PM
  5. Replies: 0
    Last Post: 22-06-2014, 01:59 PM
