Thread: Rotary Table CNCing
Peter, can you explain further. I was looking at sintered bushes with a view to taking a .375" ID .6" OD bush, opening out to 10mmID and turning it down to 15mm OD. It will have less friction than cast-iron to cast-iron. But as I said above, the torque requirement at the moment seems to be OK with a 1Nm motor so maybe I'll leave that till later if needed. The end-float I can set now with a 1.5thou feeler gauge and the motion feels smooth. The worm is a 2mm pitch approx so, if my calcs are right, this represents an additional 5 or 6 minutes of backlash on top of the 15minutes already present and this can be taken up by the software
19-02-2010 #2
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
CNC Rotary table/lathe head indexing
By Kwackers in forum Electronic Project BuildingReplies: 40Last Post: 09-12-2011, 03:33 PM -
Which chuck to fit 6" rotary table??
By wiatroda in forum General DiscussionReplies: 19Last Post: 10-08-2011, 08:47 AM -
Mounting a chuck on a Rotary table
By irving2008 in forum Machine DiscussionReplies: 17Last Post: 02-09-2010, 07:23 PM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
