15-08-2025 #11
Hello
Attachment 32696 still give an error: "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
David
16-08-2025 #12
I’ve moved @dh42’s post here to keep the other thread clean, as this seemed the most relevant place for it.
Hi David,
Sorry I missed your post at the time, I’ve just worked out what’s going on with some attachments failing while others work fine.
It seems to happen when you try to add images via the Quick Reply box. If you hit the Go Advanced button instead, you’ll get a new page with an Attachments section below the message box. There’s a Manage Attachments button there, and using that to upload (or manage previous uploads) works fine for me - tested in Chrome on desktop.
As I mentioned in another thread, this has been a long-standing quirk. I’ve got bigger upgrades coming, including a proper migration to a new platform, and I’ll share more on that soon.
In the meantime, to try and reduce the confusion for new members when their images don’t appear, I’ve removed the attachment icons from the quick reply header for now. Not ideal, I know but at least it should save people from hitting the same frustration until the proper fix is in place.
Thanks, again for your patience and for sticking with it.Lee
16-08-2025 #13
"It seems to happen when you try to add images via the Quick Reply box. If you hit the Go Advanced button instead, you’ll get a new page with an Attachments section below the message box. There’s a Manage Attachments button there, and using that to upload (or manage previous uploads) works fine for me - tested in Chrome on desktop." (sorry, can't find the "quote" button on the "advanced" editor )
Test in advanced mode (and "insert InLine")
seems to works !
David
The Following User Says Thank You to dh42 For This Useful Post:
16-08-2025 #14
16-08-2025 #15
Ok, nice using bbcode tags directly seems to works ;)
[ code]Code:' setting menu clicked - open the form Public Shared Sub DimArrow_set_clicked(ByVal sender As Object, ByVal e As EventArgs) 'menu settings clicked 'show the settings form 'attach the tool windows to the main cambam window, and open it Dim f As Form = New ClassDimArrow.DimArrow_settings ThisApplication.TopWindow.AddOwnedForm(f) f.ShowDialog() End Sub
f.ShowDialog()
End Sub
[ /code]
the space after [ must be removed for the tags to woks. I use it only to show the tag text (seems code tags must not be used into another code tag, because the appears as nested code instead to show the tag text)
[ quote]Nice, you can use the "Reply With Quote" in the lower right of said post: [ /quote]Nice, you can use the "Reply With Quote" in the lower right of said post:
Size:
[ b]Size:[ /b]
VERSION_CODENAME=bookworm
[ size=1]VERSION_CODENAME=bookworm[ /size]
[ size=2]VERSION_CODENAME=bookworm[ /size]
[ size=3]VERSION_CODENAME=bookworm[ /size]
good night ;)
David
There are currently 15 users browsing this thread. (0 members and 15 guests)
servo motor and its driver are acting strange
By jhonansaro in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 29-04-2018, 04:18 AM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
By GEOFFREY in forum General DiscussionReplies: 2Last Post: 09-03-2014, 09:35 AM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
Z acting Strange
By m.marino in forum Machine DiscussionReplies: 2Last Post: 06-03-2012, 09:30 PM
