02-07-2025 #1
Zero Return in FANUC CNC machines is essential to creating an accurate reference point and must be performed whenever using an absolute position encoder, otherwise home positions must be manually reset manually. Below is a step-by-step guide on how to accurately set the zero return position.
Manually move the machine to the home position, set parameter 1815 #4 = 1, shut down the machine and restart with power off, that is to determine the current point as the home position.
If 1815 #4 cannot be set to 1
- Ensure that the Motor rotates at least one revolution or more
- Set parameter 1815#5=0, 1815#4=1, 1815#5=1, power off and restart.
If 1815#5 APCx = 1, use absolute position encoder
If 1815#5 APCx = 0, use relative position encoder
If 1815#4 APZx = 1, the absolute encoder zero return is successfully set.
If 1815#4 APZx = 0, absolute position encoder home position is not set. (Alarm 300 will be generated)
If 1815#1 OPTX = 1, Full closed-loop mode enabled..
If 1815#1 OPTX = 0, Semi-closed-loop mode enabled.
For best results when using an absolute position detector, the initial adjustment or when replacing one must be set to 0, with home position later set manually back to reference point or other operations when power returns on after restart. When position correspondence between mechanical position and absolute position detector is achieved, this parameter will automatically set back to 1.
03-07-2025 #2
Tibor, welcome to the forum!
Is this the start of your spam journey?
I have moved your thread to the correct section and you are welcome to be part of the community, however we will NOT tolerate any kind of spam and you will be removed without hesitation.Lee
07-07-2025 #3
Hi Lee,
Thank you for the warm welcome! I completely understand and respect the rules of the forum.
I'm here to learn from others, share experiences, and contribute where I can — definitely not to spam.
Looking forward to being an active and respectful member of the community.
If there’s anything in my post that seems inappropriate, please feel free to let me know and I’ll be happy to adjust it.
Sharing my Router CNC workshop. looking for advice
By DanDi in forum Workshop & EquipmentReplies: 0Last Post: 21-07-2021, 11:36 AM -
fanuc om
By arif_zid in forum CAD & CAM SoftwareReplies: 0Last Post: 19-07-2018, 11:54 PM -
NEW MEMBER: Denford VMC 1300 return from the grave? (and hello from Cheltenham Hackspace)
By Chas Ixion in forum New Member IntroductionsReplies: 4Last Post: 18-12-2016, 09:57 PM -
Looking to return to CNC milling/turning
By Wafflelator in forum General DiscussionReplies: 0Last Post: 23-12-2014, 02:24 PM -
File sharing
By cgw59 in forum General DiscussionReplies: 7Last Post: 02-07-2010, 07:53 AM
