    I was starting my X3 recently and I'm not sure wha happened, but now it doesn't work at all.
    There was a pop on starting, maybe also something not sounding right in the motor drive.
    I checked the 5A fuse on the side of the mill column and it was black and clearly blown, but I then had a report from the house that an MCB had tripped there. Later I found out that an MCB had tripped in the workshop as well.
    It turns out that there might have been some local atmospheric electrical activity (lightning) when I tried to switch the mill on.
    I have replaced the 5A machine fuse and reset all MCBs, but the mill will not start.
    Is it possible that if there was local atmospheric electrical activity, this has caused the mill PC Board to blow?
    What do experience do you have of this?
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Far more likely that the drive board has failed, causing the the fuse to blow and tripping the MCBs (might even cause a leak to earth, which would trip RCDs as well)
    Depending on the X3 supplier (X3 is a fairly generic design, with a few different manufacturers, and each manufacturer offering customisation options for each buyer, so the actual spec varies quite a bit between suppliers), the spindle drive boards can be quite temperamental, and often release their magic smoke randomly.
  1. Sieg SX4
    By Spaghetti Masters in forum Marketplace Discussion
    Last Post: 21-09-2022, 06:13 PM
  2. SIEG KX3 - $ axis with Servo motors and Sieg PC controller
    By David in forum Sieg Milling Machines
    Last Post: 19-09-2019, 10:04 PM
  3. Sieg - KX1
    By ptjw7uk in forum Milling Machines, Builds & Conversions
    Last Post: 31-07-2016, 11:25 AM
  4. FOR SALE: Sieg x3
    By andris in forum Items For Sale
    Last Post: 25-02-2014, 06:32 PM
  5. Sieg SX2 in the UK?
    By TheChunk in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2010, 03:00 PM
