    Hi, can anyone in the know please help. Here is the set up. Lathe converted to mach3. No limit switches on machine yet. G-code produced by fusion 360. The test piece is to machine a 17mm bar down to 10mm diameter for a length of 30mm. The simulator within fusion 360 looks ok.
    With the lathe, first I don’t understand offsets fully so only use clearance movements set out in fusion. I move the cutter to the outer edge of the material. Set mach3 home in this position and also part zero on both axis.
    However when I start the job the tool just moves towards the chuck without cutting and I need to stop the job.
    The start point should be the front leading edge of the material so I don’t understand what is going on. Can anyone point me in the right direction. Thanks
    dh42's Avatar
    Lives in Sorbiers, France. Last Activity: 3 Weeks Ago Has been a member for 0-1 years. Has a total post count of 14. Received thanks 4 times, giving thanks to others 0 times.
    Hello
    Maybe a track ; With Fusion and Milling GCode, Fusion always write a G28 at the beginning of the code ; I don't know if it is also the case with turning Gcode, but if it is the case, you can remove the G28 to do a test. Note that the G28 return position is defined in Config/Homing limits menu.
    If removing the G28 in the Gcode do the trick, you can permanently remove it by editing the post processor and change the "safe retract" value.
    Have a look on the picture on this subject.
    http://www.metabricoleur.com/t20125-...e-gcode#398279
    David
  1. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  2. emco pc turn 55 conversion to mach3
    By Geoff57 in forum Machine Discussion
    Last Post: 02-02-2019, 06:21 PM
  3. Mach3 turn screen missing items / incomplete?
    By mondrota in forum Artsoft Mach (3 & 4)
    Last Post: 27-02-2018, 06:30 PM
  4. Mach3 Turn Screenset
    By davo453 in forum Metalwork Discussion
    Last Post: 21-04-2017, 11:19 AM
  5. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
