    I have a 6040Z machine which although is not the best it suits my needs, however after years of not being able to use it , when Covid reared its ugly head I had a lot of help from members one in particular and managed to set the machine up to the Mach3 programme, Unfortunately my control box has the old style printer ports and I can only use an old computor with windows 98.
    I used inkscape to design my projects and then JScut to convert to G code, which again took me a long time to understand but I managed.
    I Joined a mens shed to increase my understanding of a different programme, they are using Pixelcnc which is a lot better than Inkscape and JScut combined.
    I would like to be able to run my cnc machine with Windows 11 but will need a new controller, can anyone recommend a complete controller as I do not wish to build one, presumably it will have a USB control lead between the computer and control box.
    Look at the UC100. Plugs into PC using USB and control box plugs in using existing printer plug. All works with Mach3. Designed for exactly your situation! While there may be cheaper options, this is probably the easiest.
    Thanks I did start looking after I posted my question and found a thread about the adapters, they are pricey so I was going to see what replies came up and then ask if the UC100 was any good and who supplies the best one
    The answer to who supplies the best one is either CNCdrive (who make them) or, in the UK, CNC4YOU. CNCdrive have an active support forum available if you need any help. I use a couple of the big brothers of the UC100 (in fact, UC300) and they just work. Never had any problem with them.
    You will also see UC100 advertised on various other web sites. Be aware that there are a lot of fake versions around that nearly but not quite work. There are also a lot of "USB motion controllers" available via eBay and other places. They may work as advertised. I don't personally have any experience of them, and there is a fair chance that there is no technical support available from the supplier. On the other hand, there seem to be some available for less than a tenner, so maybe it's worth a gamble! Double-check their power requirements if you do go down that route - the one on my screen at the moment needs a 24V supply, apparently, and I have no idea if this is available in your system.
    You can also find "USB to parallel port" converters. These are designed to work with printers, not CNC systems, and are very unlikely to work in your system.
    Thanks I will have a look, I now need to get to grips with pixelcnc, not easy to understand via tube, as it is too quick for an old timer like me, even though they are tutorials they assume they you know what there doing plus the menus that pop up are too small to see clearly and disappear too quickly.
    I went to the men's shed this afternoon hoping to get some hands on tuturing but the right guys never came. Back to tube 😁
    dh42's Avatar
    Lives in Sorbiers, France. Last Activity: 24-06-2026 Has been a member for 1-2 years. Has a total post count of 14. Received thanks 4 times, giving thanks to others 0 times.
    Hello
    Just for info: Mach3 and parallel port can works on Win XP, Win7 and Win8 but only on 32 bits systems. It do not works with win10/11 with parallel port, no mater the system is 32 or 64 bits.
    Yes, and be careful, as said Neal, you can find UC100 on amazon, ebay and so one at very low price, but it is fakes ! (text in red)
    https://www.cncdrive.com/UC100.html
    A weakness of the UC100USB is its micro USB connector which sometimes causes connection problems. On the French forum that I regularly visit, several people had to exchange the product for after-sales service because of this problem. Even if it is a little more expensive, I would recommend the Ethernet version (UC400ETH) which does not cause this problem and, in addition, it is less sensitive to EMI. (especially for those that use a VFD spindle)
    In addition, you can plug 2 breakout boards to the UC400ETH, so you can increase the number of inputs/outputs that can be used if needed.
    David
    I have ordered a UC400 along with the ribbon cable from cnc4u I took my controller cover off to plan how I would fit it in, I released the breakout board with the parallel port on it as I somehow have to connect the ribbon cable and get it back inside the box , however the white wire from a 5 pin din socket mounted on the box was adrift, it has a single pin socket on the end, in the centre of the breakout board there are two pairs of small pins, one set marked E stop. The other pair marked probe. Where does the white wire go.
    How do I post pictures?
    dh42's Avatar
    Hello
    Click on the "insert image" button (the 3rd from the right) then select the "from computer" tab, click on "browse" and select an image from your hard drive .... and, I don't know for the rest !!!! , at this point I stay blocked, no OK or Cancel button in the popup widows and this windows do not disappears until I close it, but no image or attachment.... sorry, maybe Lee can help you ..
    I tried your attachment but I get "invalid attachment" for both links ...
    David
    Many thanks, I have my answer about the board from Doddy who had some photos from 2020 when he did a mod for me. As for the photos, that's what I did but it obviously doesn't work for me
There are currently 11 users browsing this thread. (0 members and 11 guests)
  1. 60 40 Controller
    By Norman in forum Workshop & Equipment
    Last Post: 06-08-2025, 09:47 PM
  2. What controller would you recomend?????
    By ravihotwok in forum Control Hardware & Systems
    Last Post: 06-12-2024, 08:28 AM
  3. CNC controller
    By clivemgriffiths in forum Chinese Machines
    Last Post: 30-12-2021, 04:06 PM
  4. Usb controller
    By pemmott in forum Artsoft Mach (3 & 4)
    Last Post: 02-12-2019, 07:34 PM
  5. Controller Box
    By M250cnc in forum Motor Drivers & Controllers
    Last Post: 21-11-2010, 01:34 AM
