Thread: 6040cnc controller
13-08-2025 #7
I have ordered a UC400 along with the ribbon cable from cnc4u I took my controller cover off to plan how I would fit it in, I released the breakout board with the parallel port on it as I somehow have to connect the ribbon cable and get it back inside the box , however the white wire from a 5 pin din socket mounted on the box was adrift, it has a single pin socket on the end, in the centre of the breakout board there are two pairs of small pins, one set marked E stop. The other pair marked probe. Where does the white wire go.
How do I post pictures?
60 40 Controller
By Norman in forum Workshop & EquipmentReplies: 2Last Post: 06-08-2025, 09:47 PM -
What controller would you recomend?????
By ravihotwok in forum Control Hardware & SystemsReplies: 7Last Post: 06-12-2024, 08:28 AM -
CNC controller
By clivemgriffiths in forum Chinese MachinesReplies: 0Last Post: 30-12-2021, 04:06 PM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM
