Each of those "angular contact" bearings is only designed to withstand thrust in one axial direction, so they are used in a back to back pair, ideally with some controlled preload. If they used only one such bearing, there would be some unhelpful backlash.
Yes, there's some problem with the page timing out due to this bad gateway issue. Must be driving Lee round the bend! Make sure you copy the message text before trying to post it!
WANTED: CNC kit for Aluminum? Supported rails, bearing blocks, screws, spindle-controller
By 200V in forum Items WantedReplies: 1Last Post: 09-10-2016, 09:29 AM -
FOR SALE: Linear rail and bearing blocks
By Web Goblin in forum Items For SaleReplies: 9Last Post: 26-02-2016, 10:12 PM -
play in bk1204 end bearing blocks
By dazza in forum Machine DiscussionReplies: 4Last Post: 30-07-2014, 09:28 PM -
Bearing Blocks
By GTJim in forum Rails, Guideways & BearingsReplies: 1Last Post: 15-01-2013, 07:18 PM -
FOR SALE: 25mm round rail bearing blocks
By D-man in forum Items For SaleReplies: 1Last Post: 31-10-2011, 09:26 AM
