    Hi folks.
    Got given a machine that sat in a garage for a long while, trying to start it, help needed.
    Never played with Mach3 cnc's so at this point just applying all i know from me being a cnc machinist at joinery shop (SCM/Morbidelli 430s) and owning couple of lasers (100W DSP CO2 gantry and 100W JPT MOPA engraver)...
    Machine is run off of RoutOut controller with custom 2.5a drivers, nema23 steppers, UC100 motion controller (USB>LPT converter thing, genuine).
    UC100 driver works fine, drivers get 24v on breakout (checked connection lugs at driver side) and driver power leds are lit, 5v supplied via usb charger, both indicator leds on breakout lit (5/24v).
    Motor Dir/Step set to x2/3, y4/5, z6/7.
    Riddled out endstops (reed switches) and estop pins, got them all to respond on pin12/13 and pin10 respectively (in mach3 diag).
    But for the life of me i cannot make motors spin. When jogging DRO changes but no motion in motors.
    I'm an absolute n00b when it comes to mach3 and hobby cnc machines. I'm sure i'm missing a lot, need help.
    Starting mach3 profile from scratch, as no info was provided with the machine. Company that make these is most likely ded...
    Some pics attached
ID:	32904   Click image for larger version.
ID:	32905   Click image for larger version.
ID:	32906   Click image for larger version.
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Routoutcnc still exists, but their website is only showing an Apache test page - http://www.routoutcnc.com/
    They're still active on eBay ( https://www.ebay.co.uk/str/routoutcncshop ) and their facebook page has an email ( https://www.facebook.com/routoutcnc/ ), so I'd drop them an email.
    It could their Breakout board has a chargepump circuit (it requires a constant on/off signal at a certain frequency, so that if anything happens to the controller, the machine should disable), which will need set in Mach.
  1. Troubleshooting non responsive machine- Mach3/Syil x4
    By IhateDoug in forum Machine Discussion
    Last Post: 27-02-2021, 12:22 PM
  2. Controlling the motor (spindle) with Mach3
    By northwest in forum Motor Drivers & Controllers
    Last Post: 06-09-2019, 08:39 PM
  3. Brushless DC Motor - Mach3 Compatible - Opinions?
    By smartbusa in forum Brushless Spindles & Motors
    Last Post: 23-12-2015, 11:42 AM
  4. Stepper motor drive using mach3 from parallel port
    By hmarwat370 in forum General Electronics
    Last Post: 04-02-2013, 08:55 AM
  5. Reversing motor direction in Mach3
    By bruce_miranda in forum Artsoft Mach (3 & 4)
    Last Post: 16-11-2008, 06:54 PM
