    Sorry if this is the wrong place.
    After looking around at the various options its left me with even more questions. What I can't tell is which maker is actually good. There's a plethora of inexpensive motors out there but what I don't want to do is buy one that barely lasts the warranty period.
    Can anyone point me at a make with proven reliability/longevity?
    Spec I'm looking at is ER20/80mm body/air cooling preferred but would consider water cooling/2.2Kw or a little higher/suitable inverter that can be remote controlled.
    I have 415v 3 phase at home so powering industrial controls wouldn't be an issue.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    A watercooled spindle will last far longer than any brushed motor, plus be far quieter in operation, so I'd personally get a 2.2kw (or lower powered if the size suits better).
    I wouldn't bother with 3 phase at 2.2KW, as if the rest of the machine is single phase, it just needlessly complicates things.
    Fair enough. I put the note on about 3 phase because it opens up other options.
    As yet I've only found one UK company selling these motors (as a complete kit) but they've been out of stock for a long time. Are there any recommended suppliers here in the UK?
    You could try getting in touch with Dean at jazzcnc.co.uk
    He may have a motor that he is willing to sell.
    Regards
    Mike
  5. The Following User Says Thank You to mekanik For This Useful Post:
  6. #5
    CNC4YOU appear to list vfd+water-cooled 2.2KW kits in stock. Not the cheapest compared to direct-from-China but I've been running one of their motors for years. A Huan Yuang (spelling?) VFD from somewhere else, though, and a cheap 12V caravan water pump running off 5V.
  7. #6
    Hi, for an ER20/80mm spindle, I’d go with a good quality 2.2kW water-cooled model. They are generally much quieter and last significantly longer than the cheap air-cooled ones, especially if you run jobs longer than 30-45 minutes.
  1. Recommendations for stepper motor debug / repair
    By Cotswold Woody in forum Stepper & Servo Motors
    Last Post: 05-08-2018, 07:07 PM
  2. Spindle motor
    By Lodds in forum Spindles & Drive Motors
    Last Post: 22-12-2017, 02:58 PM
  3. Replies: 2
  4. Spindle Motor
    By pdl in forum Stepper & Servo Motors
    Last Post: 09-08-2011, 10:56 AM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
