Thread: New Member
28-10-2025 #1
I would like to introduce myself. I am a 77-year-old male retiree from County Durham, UK. I'm sorry if I have introduced myself in the wrong place, if that is right, could you guide me to where I should have been
My favourite pastime is creating things from 2nd-hand wood. The proceeds of which are donated to our local Historical Society charity.
These donations help raise funds, firstly to pay for administration, seaside trips for the village children, days out for our senior citizens, and more events.
As I suffer from arthritis in my wrists, it makes it harder to complete my tasks. This is the reason I'm exploring going down the CNC route, as my niche
contains a lot of cutting shapes using a band saw. I'm hoping the CNC machine will be able to do this task for me
I will have to learn how to set up the CNC machine to cut shapes from a piece of plywood. Each shape has to be precisely the right size to fit into the finished project.
Is it possible to do this with a CNC machine?
Regards,
Nitram.
15-11-2025 #2
Hi nitram, welcome aboard.
I'm actually logging in after quite a long absence from the forum, having built my machine some years ago and now just get on with using it.
What you want can easily be done by the kind of 3-axis CNC gantry router that is by far the most common type of machine you will see.
Do you want to buy a machine or build one?
As well as the machine itself you will need to choose a software package in which to do your drawing and that will then create the instructions (G-Code) that the machine will follow. There are several choices here depending on your budget, how much time you want to spend learning to drive it and the complexity of the projects you want to make. I'm sure others will add to the list below but these are the 3 packages I have some experience with:
Fusion 360: This is a very powerful, professional standard tool which is free for hobby users. It will do everything you want but is probably way more complex that you need and will require a lot of time to learn. I haven't mastered it and have never actually managed to complete a project using it.
Vectric Vcarve: A favourite with many people, but somewhat expensive. You can buy the Pro version or the Desktop version which is half the price but restricted to 24 inch square projects. I have the desktop version. Vcarve (and especially it's much more expensive cousin Aspire) is good for the decorative, bass-relief type projects.
CamBam: Inexpensive, quite easy to learn and very capable, especially for "engineering" type projects using 2D shapes cut out of flat material. This has been my go-to software for many years for designing things like clocks. It has a very good support forum and loads of free plugins which greatly enhance it's capabilities.
All these programs have free trial peroids so you can try them for yourself.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
16-11-2025 #3
And depending on your actual needs @NITRAM, you could do yourself a favour (and possibly extend your initial budget) and buy a UK-built CNC machine from https://www.jazzcnc.co.uk/.
There are currently 10 users browsing this thread. (0 members and 10 guests)
