10-12-2025 #4
The right answer is obviously to fit the tool changer with a home switch so that Mach3 can properly initialise it when you first start - the only way to avoid a manual operation. Not necessarily an easy task!
My own workaround would be to write a little macro that updates the internal tool number record and attach it to a button that is added to an appropriate screen, or just a check box that tells the M6 tool changer macro whether or not to move the tool changer when a tool is selected. Then you could tick the box, issue an M6T?? command to set the tool number to match the changer position, then untick the box and carry on.
This all assumes that you cannot just change the tool number by typing it into the box on screen, like a work coordinate, but I'm sure that you have tried this! I moved off Mach3 a few years ago so can't help with macros and so on but I have done exactly this kind of thing in the past so know that it is doable.
Help with setting up proximity sensors and Mach 3
By Wooddesign in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 10-03-2019, 09:27 PM -
help setting up Mach 3 to drive my CNC router
By pd110961 in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 07-06-2018, 04:02 AM -
Renishaw HPMA plus RP3 tool setting arm - FOR SALE
By topbanana in forum Classified Ads, Buy, Sell & SwapReplies: 1Last Post: 06-07-2016, 09:48 PM -
FOR SALE: Renishaw HPMA and RP3 Tool Setting Arm
By topbanana in forum Items For SaleReplies: 0Last Post: 18-02-2016, 07:55 PM -
another tool hight setting proble :)
By blackburn mark in forum Tool & Tooling TechnologyReplies: 4Last Post: 08-09-2012, 11:30 PM
